Hi!
Thanks to the Great scripting example on Results Retrieval on Shells, I manage to do similar stuff on a structural model made of beams. I wonder how I can retrieve the utilization of beams in IronPython?
Here is a snippet from the example (which works nicely!):
# ... other karamba related CLR import
import feb # Karamba's C++ library (undocumented in the API)
# clone the model and its list of elements to avoid side effects
model = model_in.Clone()
# clone its elements to avoid side effects
model.cloneElements()
# clone the feb-model to avoid side effects
model.deepCloneFEModel()
deform = feb.Deform(model.febmodel)
response = feb.Response(deform)
# calculate the displacements
response.updateNodalDisplacements();
# calculate the member forces
response.updateMemberForces();
# if something changed inform the feb-model about it (otherwise it won't recalculate)
model.febmodel.touch()
lc = 0
energy_visitor = feb.EnergyVisitor(model.febmodel, model.febmodel.state(0), lc);
energy_visitor.visit(model.febmodel);
elastic_E = energy_visitor.elasticEnergy()
max_displ = response.maxDisplacement()
The Results Retrieval example above uses the feb library’s classes like feb.Deform, feb.Response, and feb.EnergyVisitor to access the model’s results. However, the feb library seems to be a C++ backend (I can’t use inspection to probe its attributes and functions) and its API is not documented at the SDK manual.
I wonder if we can have the API of feb documented in the SDK as well? And in a shorter term, can we also have a scripting example demonstrating how we can retrieve the data that we can get from the Utilization of Elements component, in C+ or IronPython?
Thanks again for making and maintaining such a great plugin!
Best,
Yijiang
