just curious if someone has something floating around that would basically invert selected but only using objects on same layer to select? also this would only need to work with one layer for simplicity.
thank you in advance.
Hi @kleerkoat, you might try below. Works with multiple layers:
def DoSomething():
sel_ids = rs.SelectedObjects(True, False)
if not sel_ids: return
layers = set([rs.ObjectLayer(obj_id) for obj_id in sel_ids])
# uncomment below if you want only single layers
# if len(layers) > 1: return
for layer in layers: rs.ObjectsByLayer(layer, True)
rs.UnselectObjects(sel_ids)
DoSomething()
_
c.
winner winner chicken dinner! time to go DoSomething()
with this.
thank you!
i really do hate to ask, but how would i put in a prompt if no item is preselected? this is the bee’s knee’s.
That would be
def DoSomething():
if not sel_ids:
sel_ids = rs.GetObjects("Get some objects")
if not sel_ids:
return
DoSomething()
awesome! thank you kind sir!
