Hi everyone,
I can’t figure how to solve an “apparently’“ simple problem on lists.
I’m dealing with a list of values following this pattern :
{0}
[400;0;0;0;0;120;0;0;30;0]
{1}
[650;0;0;320;0;0;0;0;0;0;0;110;0]
I’d like to replace the 0 values by the previous positive value. Following this simple rule, I expect :
{0}
[400;400;400;400;400;120;120;120;30;30]
{1}
[650;650;650;320;320;320;320;320;
320;320;320;110;110]
As you could have seen, number of items in branches may differ.
I really hope someone could help me
Thanks,
Thib
Tom_Newsom
(Tom Newsom)
February 4, 2026, 8:56pm
2
Is it always that structure? Single digits separated by zeros? Never two non-zero numbers next to each other?
Does it matter if it were?
Tom_Newsom
(Tom Newsom)
February 4, 2026, 9:04pm
4
Not sure till I try, but it’s good to have clear specification of a problem
It’s just a falling edge detector.
but we are sure that the first item is not 0 ?
I would assume, but in that case make <“null”>
Tom_P
February 4, 2026, 9:59pm
9
you still have to define:
what should happen if the list starts with 0 ?
[0;0;400;0;0;0;0;120;0;0;30;0]
and yes, solve it by a simple script as @Jakob_v_Schirmeister showed.
Like I said, you then start replacement with a null.
Tom_Newsom
(Tom Newsom)
February 4, 2026, 10:23pm
11
Well, just for fun, here’s a way without a script
replace following zeros TN.gh (9.0 KB)
impressive!
(how complex/complicated vanilla can be)
but a good lesson!
Hi @Tom_Newsom & @Volker_Rakow
You’re correct, I didn’t explain a lot about the lists structure.
It always begins with a non-zero
2 non-zero numbers can be consecutive
all numbers are integer by the way
Your script Tom seems to work, but I’m facing a problem when 2 non-zero numbers are consecutive.
Volker, you may have solve my problem. I’ll test it !
Thank you both for quick answers
It should. I’ve stress-tested it. The only thing that may trip it up is negative numbers? I don’t know if you will have any of those. So for instance:
[-12, 30, -4, 0, 0, 0]
would translate to:
[-12, 30, -4, -4, -4, -4]
instead of:
[-12, 30, 30, 30, 30, 30]
and you have asked that the zeros be replaced “by the previous positive value in [the] list”
Tom_Newsom
(Tom Newsom)
February 5, 2026, 11:59am
17
Pretty sure this revision of my version covers all these reqs: consecutive non-zeros, cull leading zeros, negative==zero. If there’s some other behaviour for negatives, it’d be a simple fix.
replace following zeros TN2.gh (11.1 KB)
Either negative==zero, or negative==a non-zero to be skipped over until the first previous positive integer is found. That’s still not clear.
jeremy5
(Jeremy)
February 5, 2026, 12:42pm
19
This is trivial in code…
Replace 0 values by previous positive value in list JS Python.gh (7.5 KB)
Note that you need to set the x input to List Access mode.
HTH
Jeremy
Jeremy:
As probably most things are
