Hi everybody,
how can I render just black shadows in raytracing mode on a white plane (or transparent), hiding the related object?
Thanks for any help!
Simone
I attach an image example
Currently not possible.
Render passes not possible in Rhino - clown, shadow, depth etc?
Check in Rendering panel when Rhino Render is selected. Switch from automatic channel selection to manual. A couple of passes are possible, but currently not all that Cycles is capable of.
Thank you - I’ve tried Render channels / Custom (RGBA, Distance, Normals, Albedo) but for now nothing relevant happens
You can choose what channel to look at in the render window that pops up when using the _Render command.
