I need a script to rename objects by the layer that they are in.
Can anybody help?
Thanks !
You can try this :
objList = rs.GetObjects("Select objects to name")
for obj in objList:
layer = rs.ObjectLayer(obj)
layerName = rs.LayerName(layer)
rs.ObjectName(obj, layerName)
Cool. Thanks Baptiste.
If you don’t need the entire layer name but only the sublayer name :
for obj in objList:
subLayerNameList = layerName.split("::")
newName = subLayerNameList[-1]
rs.ObjectName(obj, newName)
or better :
for obj in objList:
layerName = rs.LayerName(layer, False)
Perfect. I was wondering about that. I might need both depending on the project. Thanks again.
Come to think about it. Can I ask you to add it as an option, for example, when I run it it could ask “Sublayers only Y/N” …
and have both options in one script ?
I wrote this, it works but it remains a bit buggy.
Maybe someone more comfortable with the scriptcontext syntax could have a look and make it better…
import Rhino
import scriptcontext
def nameObjectsFromLayerName():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select objects to name")
boolOption = Rhino.Input.Custom.OptionToggle(True, "Off", "On")
opList = go.AddOptionToggle("fullPath", boolOption)
while True:
getResult = go.GetMultiple(1,0)
if getResult == Rhino.Input.GetResult.Cancel:
return Rhino.Commands.Result.Cancel
elif getResult == Rhino.Input.GetResult.Option:
go.EnablePreSelect(False, True)
print "fullPath =", boolOption.CurrentValue
elif getResult == Rhino.Input.GetResult.Object:
ids = [go.Object(i).ObjectId for i in range(go.ObjectCount)]
break
fullPath = boolOption.CurrentValue
for obj in go.Objects():
layerName = rs.LayerName(layer, fullPath)
Baptiste, I tested it in several projects and it seems to work fine. Where did you find a buggy behavior ? I didn’t see any problem.
Actually, it’s mostly a matter of coding. I’m not sure I went right to the point and with the proper method.
From the user side, you will discover that if objects are preselected, then you cannot change the option and whenever you toggle the option, you have to make your selection again even if you already did before. Not very convenient.
If it suits you, it’s alright. I will have a look on it to find a better solution.
I was just hoping somebody would give a hand on this.
I see. Don’t worry too much. It works for now.
Thanks
