I am working on a pathnumber based subdivision these days.
The idea is the following:
A tree of meshFaces :
{0} = no subdivison
{1} = 1 time subdivide
{2} = 2 times subdivide
I got it mostly working when I use a meshplane,just some rectanlges do not subdivide all of the 4:
But the strange thing is that the same code on a meshsphere throws an index out of array exception
Or propably its not strange and my attempt is just really poor
My main code is this:
for (int k = 0; k < meshTree.BranchCount; k++)
for (int i = 0; i < meshTree.BranchCount; i++)
//get PathNumber
char[] charsToTrim = { '{','}'};
string path = meshTree.Path(i).ToString();
string pathNumber = path.Trim(charsToTrim);
int pth = int.Parse(pathNumber);
//subdivide
if (pth > 0)
for (int j = 0; j < meshTree.Branch(i).Count; j++)
meshTree.AddRange(MakeSubD(meshTree.Branch(i)[j]), new GH_Path(pth - 1));
meshTree.Branch(i).RemoveAt(j);
A = meshTree;
Maybe someone has the patience to help me with that one.
It is because mesh spheres have triangle faces at the poles. Your code only accounts for quad faces so when it hits a triangle face and your code gets to Mesh face3 which calls face3.Vertices.Add(msh.Vertices[3]); there is no Vertice[3] for it. You need to either omit triangle faces or make a condition for them.
Do you maybe also know how to remove the Meshface I subdivided from the tree, so that they arent overlaying?
meshTree.Branch(i).RemoveAt(j); // how to remove it here?
Then imagine that you want to do a “sheet” like combo from all the distorted pieces. So you need to add “diaphragms” so to speak. These are (a) main (with regard module to module [footprint defined by the x, y, pos by 0-xc, 0-yc values]) and (b) secondary (what happens inside the module: the results of the recursive Divide() Method). Here’s the main ones:
So be brave and do it (prior that read what LINQ is about).
PS: A void Method returns nothing. So it has sense if stuff inside is declared public (or privet in some class). By accident this is the way to go in recursion in order to avoid locomotive size Method calls. For some mysterious reasons NASA gurus recommend avoiding recursion at any cost.
PS: In this case the divList is public (and the Loop, Loops) so is not very clear what the public policy is all about. But in other cases you may have lot’s of related vars …
thanks for the hints!
In order to understand the void thingy I am trying to do some other stuff on meshes.
Crashing Rhino constantly, but I am on the way, hehe.
If you can wrap your head into changing recursion with iterations as the Dark Lord says, you will have less stack overflows. Unfortunately C# doesn’t support tail recursion out of the box but there’s Trampolining
Given the opportunity, here’s an entry level veeeeeeeery simple thingy (using the trampoline moniker rather optimistically) with regard bounce solving - but in real life Dcurr and Tcurr are implicitly known meaning that the if comparisons are not like the ones used (life sucks).
You could even try the most simplest of tests and a very popular one as well.
Compute the Nth number in the Fibonacci sequence recursively and iteratively and the difference is huge.
In general recursion does not perform well under many iterations because It produces many method calls, causing your stack memory to suffer some serious pain. Methods are always saved on the stack when called upon. While in a iterative solution you will only need to allocate your method a single time on the stack. The rest will depend on the complexity time that your algorithm is running at.
For example:
int64_t FibonnacciIterative(int n)
if (n == 0 || n == 1) return n;
int64_t a=0, b=1, c=1;
for (int i = 0; i < n; i++)
a = b;
b = c;
c = a + b;
return a;
int64_t FibonnaciRecursive(int n)
return fibonnaciRecursive(n - 1) + fibonnaciRecursive(n - 2);
computing the 50th term:
So the recursive version takes almost 1 minute while the iterative one is basically instantaneous…
If you are after games then C++ makes some sense. If you are in AEC stick to C#. If you are after dollars marry a rich girl, buy a proper Lambo (a Balboni, what else?) and forget all that.
