It would be nice if I can see easily the whole time it takes to run one solution somewhere and also give suggestions on how to make this real-time definition. This will become increasingly important for VR and AR. Also I wish there is a way to make a redistributable package with a definition and user friendly interface that can be launched by inexperienced people much like unity or unreal can do that.
For example I can see this but does that mean one full solve is 7.2ms?
Document: 800
Path: 800.gh
DocId: *-9356-4b78-bdb6-7561de1bbccf
Modified: False
Context: Loaded
RaiseEvents: True
Enabled: True
Nested: False
Owned: False
Current Span: 7.2087ms
Current State: PostProcess
Preview Mode: Shaded
Preview Filter: None
Preview Mesh: LowQuality
Schedule: -1ms
Subsidiary Tree
800
Object Count: 84
Undo|Redo Server
Undo Count: 107
Redo Count: 0
Undo Names: Add state, Toggle, Slider Value Change, Slider Value Change, Slider Value Change, Slider change, Slider change, Slider Value Change, Drag, Slider Value Change, Toggle, Slider change, Toggle Preview, Delete, Drag, Drag, Toggle, Toggle, Slider Value Change, Slider change, Drag, Drag, Toggle, Toggle, Drag, Slider change, Toggle, Toggle, Slider change, Slider change, Toggle, Toggle, Toggle, Toggle, Drag, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Toggle Preview, Drag, New wire, Toggle Preview, Toggle Preview, New wire, Delete, Delete, Drag, Delete, Drag, Toggle Preview, Drag, Code change, Toggle Preview, Drag, Drag, Drag, Toggle Preview, Drag, Code change, Slider change, Toggle Preview, Drag, Drag, Slider change, Slider change, Slider change, Slider change, Drag, New wire, Drag, Add Number Slider, Drag, New wire, Add List Item, New wire, Drag, Drag, Drag, New wire, Drag, Delete, Drag, Add List Item, Add Tree Item, Toggle Preview, Toggle Preview, Drag, Toggle Preview, Toggle Preview, Drag, Drag, Toggle Preview, Drag, Drag, New wire, Add Point, Drag, Toggle Preview, New wire, Resize Panel, New wire, Add Panel
Event Server
Enabled: True
Update: False
