Read file not working
in the latest MRhino 6 WIP, the " read file" component doesn’t work (red from the moment in appears).
Rhino 6 SR12 2018-11-13 (Public Build, 6.12.18317.12076, Git hash:master @ 069b1aed33ba5c9e6b04dd9e509ff8509a57719d)
Licence type: Bêta, version 2018-11-13
License details: Cloud Zoo. In use by: Nicolas ()
Expires on: 2018-12-28
Apple Intel 64-bit macOS Version 10.13.6 (assemblage 17G3025) (Physical RAM: 8Gb)
Machine name: chalet
Language: fr
NVIDIA GeForce GT 650M OpenGL Engine (OpenGL ver:4.1 NVIDIA-10.33.0 387.10.10.10.40.108)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Driver Date: (null)
Driver Version: (null)
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Displays: LCD couleur (129dpi 1x)
Screen size: 1680 x 1050
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Apple Inc.: Bluetooth USB Host Controller
Seagate: M3 Portable
Logitech: USB Receiver
Bluetooth devices
None
Third party kernel extensions
com.usboverdrive.driver.hid (3.3) E22A11CE-9332-3618-AAEF-8ABE6C34C021
com.nvidia.web.NVDAResmanWeb (10.3.3) 92230D7F-69C4-34B2-9B37-2BA3E8131CE1
com.nvidia.web.GeForceWeb (10.3.3) 511F916F-8665-3F9B-8036-266E13801715
com.nvidia.web.NVDAGK100HalWeb (10.3.3) 8839B076-B7DE-3CF3-A02D-9BA3B751A1F6
com.objective-see.lulu (1) CFE5A74B-7CB0-3B93-A00B-FE2EFA25200D
com.nvidia.CUDA (1.1.0) E13478CB-B251-3C0A-86E9-A6B56F528FE8
Third party plugins
/Library/GPUBundles/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
/Library/GPUBundles/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
/usr/local/cuda/lib/libcuda.dylib
/Library/Frameworks/CUDA.framework/Versions/A/CUDA
/Library/Frameworks/CUDA.framework/Versions/A/Libraries/libcuda_387.10.10.10_mercury.dylib
/Library/Frameworks/CUDA.framework/Versions/A/Libraries/libfatbinaryLoader.dylib
/Library/Frameworks/CUDA.framework/Versions/A/Libraries/libptxJitCompiler.dylib
Rhino plugins
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp “Alerter” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.12.18317.12076
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.12.18317.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 5.1.2015.132
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.12.18317.1002
Hi @nico,
Thanks for taking time to report the issue! I believe we have this logged here.
Do you have a .gh file that we can test when we fix the issue to ensure it will work for you case?
Thanks!
Curtis.
Hi Curtis,
Yes, it seems it is the same issue.
Sorry for reporting an already known problem, I only checked on the forum and not properly on youtrack:/
To test if it is working, I think you just have to use the “read file” component in a blank grasshopper definition.
Have a good day,
Nico
That’s no problem, having it posted on the forum will help others find it too. (;
(It also gives me a mental note to bump up its priority the more I hear about it).
Cheers!
Curtis.
This should be fixed in the latest RhinoWIP. Please give it a try.
Good news!
From the quick tests I just did, it seems to be effectively fixed.
Have a good day,
Nico
