I don’t recall having this problem in R7
Are you able to test Rhino 7 with your code to see if this is a regression?
If not, do you have some code so I can replicate?
Just tried it in Rhino 7, Custom view didn’t show up. It’s a regression for sure.
Try to run the below command in Rhino 7 and Rhino 8. I think you would replicate the issue I have.
var viewportControl = new Rhino.UI.Controls.ViewportControl();
return Result.Success;
Thanks @Wiley,
I can repeat this behaviour, I’ll look into why this is
bump
I’m still looking into this, apologies it’s taking a while.
bump
@CallumSykes
bump
@CallumSykes bump
bump
bump. this still hasn’t been fixed
I’ve also noticed this. Have kind of a janky work-around where I just close the view that was created right after, e.g.
string viewportName = "The name";
// Note that when we instantiate a ViewportControl, Rhino automatically (for some reason)
// creates a view by the name we passed. i.e. a view at the same level of
// Perspective, Top, Front, Right. We don't actually want it. So at the end of the function
// we search for that newly-created view and close it.
ViewportControl viewportControl = new(viewportName);
ViewportControl = viewportControl;
viewportControl.Viewport.Name = viewportName;
// Close the newly-created view
var view = RhinoDoc.ActiveDoc.Views.Find(viewportName, true);
view.Close();
Hi @Wiley,
Can you provide a simple example, that I can run here, that repeats the issue?
Thanks,
– Dale
I see the issue has been logged, but not activity on it.
@CallumSykes - were you ever able to bisect this?
