Quick Question on Ladybug - LB Direct sun hour
Hello all,
I am trying to figure out other ways to fix this problem, saying, “input parameters_vectors failed to collect data.”
I tried changing to other locations and changing the file path with a downloaded file, but I can’t think of what else I can try to find this problem.
Here’s the image of it:
Any ideas, insights, and thoughts will be very helpful.
Thank you.
Hi @Suk-Hee ,
You will likely get more help over here:
I don’t have access to your file but it appears the vector output of your Ladybug Sun Path component has null vectors. Meaning something in that component is causing it to return null. Likely a lack of required parameters being filled out on that component somewhere.
Hi Michael.
I didn’t know there was a forum for the ladybug. Thank you for the information and your thoughts on my question!
You’re welcome, I hope you find the answer to your question over there!
do you have a solution?
Please check https://discourse.ladybug.tools/
