Hi.
I want to use Eddy3D to calculate the wind pressure coefficient of a building envelope and use the calculated wind pressure coefficient as input to ‘Energyplus-airflownetwork’.
At this point, the basic equation for calculating the wind speed by height in ABL in Eddy3D and the equation for calculating the wind speed by height used in ‘Energyplus-airflownetwork’ are different.
The equation used to calculate wind speed by height in ‘Energyplus-Airflownetwork’ is as follows
I want to use the wind speed by height calculation formula used in Energyplus - airflownetwork in the ABL settings in Eddy3D.
Is there any way to change the ABL wind speed formula in Eddy3D and use it? Or is there a way to import an excel or txt file with wind speed data by height and use it as ABL, like in the following example?
Additionally, I would like to know where I can check the wind speed by height generated by ABL.
Best regards.
