Question about GeometryBase
Could someone help me understand how to move from a GeometryBase data type into its actual object type. I am kinda new to C# so bear with me. How do I go from geometrybase type to a polycurve type? I guess I am asking after getting to the geometrybase type how do I pivot to its intended class to access methods of interest. Is there something I am missing conceptually ?
here is some basic code I was noodling with. In this case I would like to convert any polycurves that have the name Test to nurbs curves. But I cant access the ToNurbsCurve method because its actually a geometry base not a polycurve despite reading out like a polycurve when calling .tostring().
Thanks !
            ObjectTable doc_objs = doc.Objects;
            LayerTable l_table = doc.Layers;
            //RhinoApp.WriteLine(l_table.GetType().ToString());
            foreach (var ott in doc_objs)
                //RhinoApp.WriteLine(ott.ToString());
                //RhinoApp.WriteLine(ott.Name);
                if (ott.Name == "Test")
                    var geom = ott.Geometry;
                    RhinoApp.WriteLine(geom.ToString());
                    if (geom.ToString() == "Rhino.Geometry.PolyCurve")
                        var targ_c = geom.ToNurbsCurve();
                    //targ_geom.Add(ott);
Good Morning, there is a good guide to getting started here
Rhino - Your First Plugin (Windows) (rhino3d.com)
Once you have made your geometry you need to add it to the document, you should have a reference to a document but if not you access RhinoDoc.ActiveDoc
Then you can access the ObjectTable which provides many Add methods.
doc.Objects.Add(mygeometry);
You can also pass in the Object Attributes as a parameter which will allow you to define which layer the geometry is on.
More info in the API Doc’s https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.tables.objecttable/add
@david.birch.uk Thanks for the reply !
I am just a little confused because when I loop through all the objects within the object table and print them I see that they are Rhino.Geometry.PolylineCurve but I cant seem to access any methods from that class ? What could I be missing ?
                var test_obj = ott.Geometry;
                RhinoApp.WriteLine(test_obj.ToString());
The result is
Command: OBJtesting
Rhino.Geometry.NurbsCurve
But I cant seem to access the methods within these classes.
test_obj is a Rhino.Geometry.GeometryBase type. How would I convert its respective type (PolyCurve, NurbsCurve,ect)
try playing with this
foreach (var obj in doc.Objects)
    var curveObject = obj as Rhino.DocObjects.CurveObject;
    if (curveObject != null)
        RhinoApp.WriteLine("obj is curveObject: {0}", curveObject);
    else
        RhinoApp.WriteLine("obj is: {0}", obj);
    var geometry = obj.Geometry;
    RhinoApp.WriteLine("geometry: {0}", geometry);
    if (geometry.ObjectType == Rhino.DocObjects.ObjectType.Curve)
        var nurbsCurve = geometry as Rhino.Geometry.Curve;
        if (nurbsCurve != null)
            RhinoApp.WriteLine("nurbsCurve: {0}", nurbsCurve);
as jdhills sample shows
the actual conversion from geometry base to say Curve is done using a Cast in C#
in this case the as operator is performing the cast from geometrybase to curve
C# Type Casting (w3schools.com)
Casting and type conversions - C# Programming Guide | Microsoft Learn
@jdhill Thanks for this I was playing with it last night, I see now.
@david.birch.uk Thanks for following up ! Ill get back to studying C# !
