When it comes to panelization everytime I need to do something like this I feel like the discussions are pretty limited and always end up giving up because its ‘too complex’. I just assume panelization takes a team of expert modelers and thats the examples we see constructed in the real world.
Is it really that hard to subdivide a mesh into equal rectangles?
Right, suppose its a range then. Quadremesh does not allow the user to input a range of edge lengths. Is it really hard to achieve something like this in grasshopper maybe using Kangaroo?
Hello
it seems that tour text has many contradictory specifications.
By definition a quad mesh has line edges. The only deformation possible is to have 2 triangles. Meshing doesn’t seems to be the good tool.
Do you think you could recover your surface with gold sheet without overlapping ? I think you are limited to Developable surface. Some cuts will be necessary on the borders.
It could help if you give what you are after ? Metal fabrication, roofing … ?
In other words, I just want to create a custom quadremesh command that lets you input an edge length domain, pretty similar to RemeshByColor, but with quads, and in this case color will not be driving the subdivision but instead deviation from the original mesh.
