Q: CSharp-Example for ViewCaptureSettings(), and CaptureToBitmap()?
Hi…,
it seams ViewCaptureSettings() isn’t working in Python at the moment: https://mcneel.myjetbrains.com/youtrack/issue/RH-85062
I assume ViewCaptureSettings() is only working in the ScriptEditor with CSharp.
Is there a little example in CSharp for the ScriptEditor, which shows how ViewCaptureSettings() with CaptureToBitmap() works?
Thanks
Michael
How about the following link?
Hi @11159,
thank you, that helped me very much.
I was able to get this CSharp-Code to run in the ScriptEditor:
using Rhino;
using Rhino.Display;
using System;
using System.IO;
var settings = new Rhino.Display.ViewCaptureSettings( RhinoDoc.ActiveDoc.Views.ActiveView, new System.Drawing.Size( 1024, 1024 ), 300);
settings.RasterMode = true;
settings.ViewArea = ViewCaptureSettings.ViewAreaMapping.Extents;
System.Drawing.Bitmap bitmap = Rhino.Display.ViewCapture.CaptureToBitmap(settings);
if (null != bitmap)
    string path = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);
    string filename = Path.Combine(path, "Snapshot_1024x1024.png");
    bitmap.Save(filename, System.Drawing.Imaging.ImageFormat.Png);
Nethertheless, I’ve failed to output my PNG without borders. I was hoping to define the rastered View by numbers, e.g. 0,0,10,10, but it didn’t work.
Attached a sample graphics, which I want totally raster to a 1024x1024 pixel PNG (without borders): wave.3dm (808.3 KB)
Any help is appreciated.
Thanks
Michael
What borders are you talking about?
When I run your code I don’t see any borders around the captured view.
I see this:
Result:
Hi @nathanletwory,
sorry about the misunderstanding.
I was talking about a 2D Top view, like in my example wave.3dm file from above.
I think I have found some workarounds with the command
_SetZoomExtentsBorder _ParallelView 1.0
to fix my border problem.
Thank you again
Michael
I still don’t understand what the border issue is.
Try my wave.3dm file.
I see.
That is actually possible with SetWindowRect(Point3d, Point3d), but even then there’s a slight border still.
// #! csharp
using Rhino;
using System;
using System.IO;
settings.SetWindowRect(new Rhino.Geometry.Point3d(0,0,0), new Rhino.Geometry.Point3d(10,10,0));
if (null != bitmap)
I have logged this as RH-87393 ViewCapture.CaptureToBitmap captures with small border
Hi @nathanletwory,
thank you for your engagement.
// #! csharp
using Rhino;
using System;
using System.IO;
settings.DrawBackground = false; // doesn't work
settings.DrawAxis = false;       // doesn't work
settings.DrawGrid = false;       // doesn't work
if (null != bitmap)
Now I also noticed that the ViewCaptureSettings properties DrawBackground, DrawAxis, and DrawGrid have no effect.
Is this a bug too, or I am missing something?
Michael
I don’t know, but sounds like it. I’ll tag @rajaa here in case she can enlighten us more on this topic.
I can see what’s happening …for both extents and windowed captures. I can also see why the grid and background settings aren’t working…I’ll make that part of the same bug report.
Note: However, if you’re using SetWindowRect, then you also need to make sure that you set the ViewArea setting to “Window” as well… for example:
settings.ViewArea = ViewCaptureSettings.ViewAreaMapping.Window;
otherwise it defaults to “View”
Fixes will probably be in the next 8.x build… It’s too close to the SR20 RC release.
Thanks,
-Jeff
RH-87393 is fixed in Rhino 8 Service Release 21
Hi @jeff,
sorry, me again. :wink:
Can I set the Antialiasing level for ViewCaptureSettings() RasterMode? I would need no Antialiasing.
var settings = new Rhino.Display.ViewCaptureSettings( RhinoDoc.ActiveDoc.Views.ActiveView, new System.Drawing.Size( png_size, png_size ), 300);
I know, I can change Rhinos global View/GPU/Antialiasing value, but that’s a bit annoying.
Thanks
Michael
Hey @Michael_Meyer ,
There is no way to control this through the ViewCaptureSettings at the moment… I’ll see if I can hook something up. If you can get access to the OpenGL settings in Common (Rhino.Options.OpenGL.AntialiasMode), then you could do this programmatically by:
  1. Saving the current value.
  2. Setting it to 0.
  3. Do your ViewCapture.
  4. Then restore it back to its original value you saved in step 1.
…worth a try until I can get something hooked into the ViewCapture mechanism.
-J
Thanks, this worked for me in C#-Script:
using Rhino.ApplicationSettings;
var antialiasing_global_backup = OpenGLSettings.AntialiasLevel;
OpenGLSettings.AntialiasLevel = 0; // None Antialiasing
// CaptureToBitmap
OpenGLSettings.AntialiasLevel = antialiasing_global_backup;
