Python with wpf
Hi everyone
I’m trying to import wpf.
I’ve put IronPython.Wpf.dll - this file I have not found in the Rhino IronPython plugin - in the same directory as my main script, and I have written the following:
import cls
clr.AddReference('IronPython.Wpf')
import wpf
from System.Windows import Application, Window
class...
There is another more elegant way?
It has worked well but only the first time I run it. The following I get this: Message: Cannot create more than one System.Windows.Application instance in the same AppDomain.
Does anyone know how to do?
Thanks
Juan
I haven’t used WPF from Python, only from C#. I’m pretty sure you don’t need Application, only WIndow to show a window. As you’re already inside the Rhino3D application, you can basically use Window.Show(). No need for Application.
Thanks menno
I solved with:
.Run(nameApplication)
I do not know how to use here Window.Show().
I have another doubt: how to destroy domains in WPF?
Hey Juan!
Can you please explain how you did succeed with this problem?
Kind regards,
Daniel
import System
import Rhino
window = System.Windows.Window()
System.Windows.Interop.WindowInteropHelper(window).Owner = Rhino.RhinoApp.MainWindowHandle()
window.Show()
Does this help?
Juan Expósito
I found another solution:
import wpf
class MyWindow(Window):
    def __init__(self):
        wpf.LoadComponent(self, 'WpfApplication1.xaml')
    def ListBox_SelectionChanged(self, sender, e):
        pass
if __name__ == '__main__':
    MyWindow().Show()
I do not know the difference at this point but thanks a lot for your fast reply!
Regards,
Daniel
