Hello!!!
i just installed Rhino 9, and i pass all my toolbar from 8 to 9!!!
but i’ve got a lot of buton like this: ! _-RunPythonScript (“X_NomenclatureTubes2.py”)
how can I add my personal script folder to Rhino, i search in options… I remenber that on the V8 I had the same problem…
but no result
Cumberland
(Cumberland)
2
You need to unlock your file. Tick the “Debloquer” checkbox, see if is working.
beezeni
4
This command should work _-ScriptEditor _R “module.py” by this post
In Rhino 9, the two commands behave differently:
_-ScriptEditor _R "module.py" finds the script using my declared paths, but it is slow (it initializes the Script Editor each time).
! _-RunPythonScript "module.py" is instant, but it only works if I give the full path to the file. With just the file name, it can’t find it.
Since -RunPythonScript is the faster option for a button, I’d like it to resolve the file name through my search paths, as it did before.
