import rhinoscriptsyntax as rs import scriptcontext as sc import Rhino import csv a = [] # new. correct because global scope def CSVlist(): sc.doc = Rhino.RhinoDoc.ActiveDoc #prompt the user for a file to import filter = "CSV file (*.csv)|*.csv|*.txt|All Files (*.*)|*.*||" filename = rs.OpenFileName("Open Point File", filter) if not filename: return with open(filename) as csvfile: reader = csv.reader(csvfile) #a = [] # wrong because function scope for row in reader: p1 = Rhino.Geometry.Point3d(float(row[0]), float(row[1]), 0) p2 = Rhino.Geometry.Point3d(float(row[2]), float(row[3]), 0) """ p1 = rs.AddPoint(float(row[0]), float(row[1]), 0) p2 = rs.AddPoint(float(row[2]), float(row[3]), 0) """ x = Rhino.Geometry.Line(p1,p2) print(x) a.append(x) #print(rs.AddLine(p1,p2)) #a.append(rs.AddLine(p1,p2)) ########################################################
I am creating a list of lines and points from text. I want to output directly to line because it is easier than managing the creation of a polyline. I can output as a text fine with start points and end points of line segments, but the conversion from text to line is invalid. What to do?
# Check to see if this file is being executed as the "main" python # script instead of being used as a module by some other python script # This allows us to use the module which ever way we want. if( __name__ == "__main__" ): if x: CSVlist()
Edit: I have attached the Label and/or Line components to a parameter, for which the representation is null
Edit2: Solved by bringing a to global scope
