Hi @eirannejad,
update 18/06 - 11:59
Issue is resolved. It turned out i did not use `ifcopenshell.api.owner` before, other than I thought. I now use `ifcopenshell.api.run('owner.create_owner_history', ...)` instead of `ifcopenshell.api.owner.create_owner_history()`Original question
I am running into an issue with the scripteditor.
I use a package ifc-openshell 0.8.0. Since yesterday I cannot load submodules anymore, that I was able to load before. Possibly since the previous rhino update?
Expected behavior
when I run this test snippet, I expect that submodule ‘owner’ will be printed among other ifcopenshell.api submodules (and that its functions are available of course)
#! python 3
print('installing python packages once...')
# r: ifcopenshell==0.8.0
# r: numpy
print('packages installed')
import ifcopenshell
import ifcopenshell.api
print(dir(ifcopenshell.api))
when I check the rhinocode package folder, they should be available
Actual behavior
‘owner’ is not printed in ifcopenshell.api submodules and not useable
Can you help me with that please?
Could you also provide me a way to install the previous rhino release so I can help testing?
Thanks,
Tim
