hello! hope u doing very well!
i need some help with python to generate a nurbsCrv from a list of points created in python script.
any idea?
thanks
any idea?
thanks
Hi @oliver.jans,
Hope you’re doing fine too!
Sure, let’s say your list of points is called, well points
, than you can do the following:
import Rhino.Geometry as rg
curve = rg.Curve.CreateInterpolatedCurve(points, 3) # 3 = degree
curve.ToNurbsCurve() # maybe redundant ?
hello @diff-arch is there any method to edit weights??
thanks!!
Take a look at the NurbsCurve class documentation. You can search for “Greville” to see all methods that you can manipulate the Greville edit points with.
@diff-arch hello again! I examined the link and thought i understood everything but was mistaken. i find it really hard to edit the greville pts very confusing. would u mind sharing some of your experience w/ me?
any time. no need to hurry
thanks!
Could you maybe explain what you want to do? It would make things much easier.
I need a pwk nurbs Quadratic Crv to edit weights of ctrl points. How do i edit weights w Python script?
I have no idea what that is! pwk?
Starting from what we had above, you could do the following to alter the control point weights:
import random
# Create an interpolated curve
# Make it rational which means that it has weighted control points
curve.Points.MakeRational()
print curve.IsRational
# Randomly change the weights
control_points = []
for i in range(curve.Points.Count): # loop through the control points by index
curve.Points.SetWeight(i, random.random()) # set a random weight for the control point at index i
control_points.append(curve.Points[i].Location) # optional
You have to tag me or reply to one of my answers directly, otherwise I won’t be notified, if you post something that I’m concerned with.
Anyways, the randomization produces quite funky results.
Perfect! Thank u for posting
