While comparing a list of hundred distances to one distance, the < only gives one true or false.
My goal is to select the indexnumbers/items within the given range of z.
python list comparison 01.gh (13.9 KB)
Hi Edward,
the x variable comes in a s a list, so you need to itterate through it’s values and compare each value individually
see this quick hack where I use the print output to dispach the points:
-Willem
For the next step I could also use for in range again. However, itemgetter is another option. In sublimetext it works when I replace the list of indices with numbers, but it would not work with a list.
I think I implement it wrong.
python list comparison 02.gh (15.4 KB)
Hi Edward,
I’m not familiar with itemgetter, but my take would be:
from operator import itemgetter
emplist = []
emplist.append(y[0])
b = rs.AddCircle(y[-1],z)
distances = []
dispatch_smaller = []
dispatch_equalorlarger = []
#handle everything in one for loop
for i,xval in enumerate(x):
dist = rs.Distance(y[-1],xval)
if (dist<z):
dispatch_smaller.append(x[i])
else:
dispatch_equalorlarger.append(x[i])
a = dispatch_smaller
b = dispatch_equalorlarger
-Willem
Hi there! I’m reviving this topic since I’m stuck in a similar problem, and I don’t get what I’m doing wrong.
I have a list that has several branches, each branch has 3 indices, I want to compare each branch so the values in the indices 1 and 2 are checked, if the two of them are repeated in another branch, then the complete branch will be placed in a list called “branches_duplicate”. If they don’t or are the first occurrence, they are to be placed in a list called “branches_unique”.
Until now it seems that I can print two lists, but they seem to be empty.
Here is my code:
# Provided list of branches
branches = [] # List of values from Model
branches_unique = [] # List to store branches with unique values at indices 1 and 2
branches_duplicate = [] # List to store branches with repeating values at indices 1 and 2
# Iterate through each branch
for branch in branches:
seen_values = set() # Keep track of unique values encountered in the current branch
duplicate = False # Flag to indicate if the branch has duplicate values
# Check each element in the branch
for i in range(1, 3): # Check indices 1 and 2
if branch[i] in seen_values:
duplicate = True
break
else:
seen_values.add(branch[i])
# Append the branch to the appropriate list
if duplicate:
branches_duplicate.append(branch)
else:
branches_unique.append(branch)
print(branches_unique)
print(branches_duplicate)
