Python ispoint in region
I am trying to check if the point is inside by using python. I do not want to use the component of it. I want to use python.
Do you might know what am I doing wrong?
There is not such thing like ‘inregion’ right?
Otherwise I need to figure out to make a brep from the curve.
Thank you for your response :smiley:
20190313 pythonispointinside 00.gh (7.3 KB)
Yes if you want to use this method then I think you need to make a brep and then call the method on the brep. It is complaining because it needs a ‘self’ - the brep to refer to…
Help on method-descriptor IsPointInside
| IsPointInside(…)
| IsPointInside(self: Brep, point: Point3d, tolerance: float, strictlyIn: bool) -> bool
| Determines if point is inside Brep. This question only makes sense when
| the brep is a closed manifold. This function does not not check for
| closed or manifold, so result is not valid in those cases. Intersects
| a line through point with brep, finds the intersection point Q
| closest
| to point, and looks at face normal at Q. If the point Q
| is on an edge
| or the intersection is not transverse at Q, then
| another line is used.
| point: 3d point to test.
| tolerance: 3d distance tolerance used for intersection and determining strict inclusion.
| A good default is RhinoMath.SqrtEpsilon.
| strictlyIn: if true, point is in if inside brep by at least tolerance.
| if
| false, point is in if truly in or within tolerance of boundary.
| Returns: true if point is in, false if not.
I think you’re looking for Curve.Contains method:
import scriptcontext as sc
plane = region.TryGetPlane()[1]
answer = region.Contains(point, plane, sc.doc.ModelAbsoluteTolerance)
ForestOwl.gh (13.9 KB)
Hey @ForestOwl,
How are ya doing?
Your question was already answered in our discussion here. The goose_revisited.gh file includes most of the methods, you need for inclusion, intersection, and/or exclusion tests.
For example, line 152 to 175 of the GHPython script, inside the method is_inside():
# Count how many vertices of the test polyline are inside, outside of or conincident with container curve
    inside_count, coincident_count, outside_count, unset_count = 0, 0, 0, 0
    for vtx in test_polyline:
        containment_test = other_curve.Contains(vtx)
        if containment_test == rg.PointContainment.Inside:
            inside_count += 1
        if containment_test == rg.PointContainment.Coincident:
            coincident_count += 1
        if containment_test == rg.PointContainment.Outside:
            outside_count += 1
        if containment_test == rg.PointContainment.Unset:
            unset += 1
    if strict:
        if inside_count > 0 and coincident_count == 0 and outside_count == 0 and unset_count == 0:
            return True # strict inclusion
        else:
            return False
    else:
        elif inside_count > 0 and coincident_count > 0 and outside_count == 0 and unset_count == 0:
            return True # inclusion with partiall coincidence
        else:
            return False
I maybe should have cleared up that a vertex is basically the same as a point in this example.
:grin:
