Is it normal for Python to do a int / int = int with imported scripts, but int / int = float when in the main script? I had everything in one script 90 / 360 = 0.25, but after I refactored and referenced via import, suddenly 90 / 360 = 0.
I changed RGBToHSV to convert the incoming ints to float() and it started working again, but it’s very weird it handles division differently in a single script vs an imported script.
# UPDATED: fix for integer division>
from __future__ import division
# end fix
from System.Drawing import Color
def HSVToColor(h, s, v):
if s == 0.0: rgb = (v, v, v)
i = int(h*6.) # XXX assume int() truncates!
f = (h*6.)-i; p,q,t = int(255*(v*(1.-s))), int(255*(v*(1.-s*f))), int(255*(v*(1.-s*(1.-f)))); v*=255; i%=6
if i == 0: rgb = (v, t, p)
if i == 1: rgb = (q, v, p)
if i == 2: rgb = (p, v, t)
if i == 3: rgb = (p, q, v)
if i == 4: rgb = (t, p, v)
if i == 5: rgb = (v, p, q)
return Color.FromArgb(*rgb)
def RGBToHSV(r, g, b):
r = float(r)
g = float(g)
b = float(b)
maxc = max(r, g, b)
minc = min(r, g, b)
v = maxc
if minc == maxc:
return 0.0, 0.0, v / 255
s = (maxc-minc) / maxc
rc = (maxc-r) / (maxc-minc)
gc = (maxc-g) / (maxc-minc)
bc = (maxc-b) / (maxc-minc)
if r == maxc:
h = bc-gc
elif g == maxc:
h = 2.0+rc-bc
else:
h = 4.0+gc-rc
h = (h/6.0) % 1.0
return h, s, v / 255
