I’m trying to get the currently selected rhino object from the Rhino document in real-time.
If I use this script with a trigger attached to the component it works fine of course:
import Rhino
sel_objs = []
def get_selected_objs():
for obj in Rhino.RhinoDoc.ActiveDoc.Objects.GetSelectedObjects(False,False):
geo = rs.coercegeometry(obj)
sel_objs.append(geo)
return sel_objs
get_selected_objs()
a = sel_objs
However, I’m trying to use event handlers so that anytime a selection change occurs, i get the most current selected object in real time. I don’t want to use the trigger as that is computationally wasteful.
I just can’t seem to get it to work without return an empty output result.
Any help is greatly appreciated!
Thank you!
Full Code:
import Rhino
class SelectionChangeEventHandler():
# Initialize sel_objs as an empty list
sel_objs = []
def __init__(self):
Rhino.RhinoDoc.SelectObjects += self.get_selected_objs
self.Enabled = True
def Disable(self):
Rhino.RhinoDoc.SelectObjects -= self.get_selected_objs
self.Enabled = False
def IsEnabled(self):
return self.Enabled
def get_selected_objs(self, sender, e):
self.sel_objs = [] # Clear the previous selected objects
for obj in Rhino.RhinoDoc.ActiveDoc.Objects.GetSelectedObjects(True, False):
self.sel_objs.append(geo)
# Assuming objs is a variable representing the output
objs = self.sel_objs # Update objs with selected objects
return objs
if __name__ == '__main__':
# Create an instance of the event handler to start listening for events
handler = SelectionChangeEventHandler()
I used it for a while but yesterday I went back to referencing an input object with python. I’m doing a lot of control point editing on meshes and need the updated mesh in Grasshopper but the select / deselect event handler does seem to detect sub object selections.
On the GHPython SDK mode side of things, one can reliably (in my experience at least) subscribe and unsubscribe to events using the __enter__ / __exit__ methods:
Edit: This appears to work if I understood the problem correctly:
I happen to need this type of feature for a user interaction experiment that I’m trying to develop, and your code has helped me understand in a level, how to trigger a grasshopper component through events. What I need to know is why does it sometimes trigger more than two times once you select and object.
Here is a example file that I use to track the times a component triggers: Select2Update.gh (3.5 KB)
If I find anything I’ll post here to update my contribution to your code.
I do have two more small feature requests if possible.
One of them it is to add a Reset button as input (I can use this to quickly enable/disable the component), and another one it is to add a small delay between calculating the selection. The second feature it is very useful when dealing with a lot of objects and want to isolate the selected ones in Rhino, my viewport freezes for a few seconds as seems that it tries to recompute multiple times the selection.
My goal it is to replace the HumanUI “Objects by Selection” which literally freezes for a few good minutes my viewport if I try to isolate the selected objects.
Hello Anders,
thank you for the script you provided!
With Rhino 7 i had no problems, but when i tried to copy and paste it into a new Python 3 component, which got released with Rhino 8, i get the Error shown in the picture.
I think it has something to do with the way the list is structured. As you can see the two Guids are listed in the same entry.
Also there apparently is something different with the event handlers, because when i change the selection, there is no change in behaviour.
Do you have an idea why and how i can make it work again?
(If not obvious, i am quite new to working with Python in Grasshopper)
That script relies on the GHPython component running in SDK mode. I’m not sure what the current status is with the new script editor supporting this feature, but either way I’d suspect it might require the component to be running IronPython (i.e. not CPython, which seems to be the case with the component in your screenshot).
Ah, i see.
I tried with the IronPython Component and got no Errors this time!
The event handlers still don’t seem to work though, as there is no updating when i change the selection.
If this is also just a matter of missing features, i think i will just stick to the old Python Component for now.
Thanks!
