I need to test a list of many co-planar curves to see if any of them intersect with any other curve in the same list and return True/False values that I am feeding into a Python Script. I was using CollisionMany|Many for this but it is already slow with my sample set of only 399 curves. My final project will be using many more curves so I would like to go ahead and see if I can get around this bottleneck. I thought since I was already using Python I could try to integrate this intersect test in Python as well (also attached as a cluster with internalized data):
# Define the input parameter
curves = x
# Initialize the result list
results = []
# Loop through each curve in the list
for i, curve_i in enumerate(curves):
# Loop through each subsequent curve in the list
for j, curve_j in enumerate(curves[i+1:], start=i+1):
# Check for intersection between the two curves
intersection = rs.CurveCurveIntersection(curve_i, curve_j)
# If the curves intersect, add True to the result list and break out of the loop
if intersection:
results.append(True)
break
else:
# If the inner loop completed without finding an intersection, add False to the result list
results.append(False)
# Output the result list
a = results
When I run this on my curves, it returns 334 True values but CollisionMany|Many returns 388. Looking at the outputs, it seems like my code is sometimes assigning True to one curve that is intersecting and assigning False to the other curve. But not all the time.
In this picture I’m selecting the curves that my script says have intersections but a couple that are intersecting are not selected:
Those red curves are in the list my script assigns False to. But they all are in the results from CollissionMany|Many.
I think it might have something to do with how I am enumerating through the list, but I’m not the best with Python so it might be something else. I don’t know how CollisionMany|Many goes about finding all the intersects so I’m unsure of what to change.
If anyone has suggestions to improve this code or a more efficient component I could try instead of CollisionMany|Many I would appreciate it.
Intersections.ghcluster (36.0 KB)
