Python Bug Grashopper
Hi every one,
i’m having some trouble with grasshopper, the thing is that the window for Python script does not work at any component for editing or writing. May be you could help me
I shear a sreen shot of my problem as well as info of my system.
From the error
System.TypeLoadException: Could not resolve type with token 0100003a from typeref (expected class ‘ObjCRuntime.NativeObjectExtensions’ in assembly ‘Xamarin.Mac, Version=0.0.0.0, Culture=neutral, PublicKeyToken=84e04ff9cfb79065’)
at Eto.CodeEditor.CodeEditorHandler…ctor () [0x00033] in <77e8364d23554eee9c1bb6f73e4a71d5>:0
at RhinoMac.Runtime.EtoStyles+<>c.b__0_6 () [0x00000] in :0
at Eto.Widget…ctor () [0x0006a] in <79d4fa420dbc462a8d3367bf88727ecc>:0
at Eto.Forms.BindableWidget…ctor () [0x00000] in <79d4fa420dbc462a8d3367bf88727ecc>:0
at Eto.Forms.Control…ctor () [0x00000] in <79d4fa420dbc462a8d3367bf88727ecc>:0
at Eto.CodeEditor.CodeEditor…ctor (Eto.CodeEditor.ProgrammingLanguage language, System.Boolean darkMode, System.Func4[T1,T2,T3,TResult] getCompletions, System.Action1[T] logger) [0x0000e] in <617794a618c548758f2c97a66d06f505>:0
at GhPython.MacForms.EtoScriptForm…ctor (GhPython.Component.ScriptingAncestorComponent parent) [0x00413] in :0
at GhPython.Component.PythonComponentAttributes.OpenEditor () [0x0002a] in :0
System Info
Rhino 7 SR5 2021-3-30 (Rhino 7, 7.5.21089.05002, Git hash:master @ 8c08ab365205eddee74c2829591c23a839506d31)
License type: Evaluation, build 2021-03-30
License details: Stand-Alone
Expires on: 2021-06-14
Apple Intel 64-bit macOS Version 11.2.3 (Build 20D91) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,2
Language: en
Intel Iris Pro OpenGL Engine (OpenGL ver:4.1 INTEL-16.1.12)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Pro
Displays: Color LCD (221dpi 2x), ASUS VA24E (93dpi 1x)
Graphics processors
Intel Iris Pro (1536 MB)
Color LCD (1440 x 900)
ASUS VA24E (1920 x 1080 @ 60.00Hz)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
Broadcom: Magic Mouse 2
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.5.21089.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.5.21089.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.5.21089.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.5.21089.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.5.21089.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.5.21089.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.5.21089.5002
@piac - the error message says this one is for you!
Thanks @pascal , this is known and tracked also in this other discussion:
and on YouTrack, at RH-63586.
Thanks.
Thank you!
