PushPull Modeling in iRhino3D
iRhino3D WIP (8.0.23154 (11.1.1) - June 6) available via Testflight makes it easier to create and manipulate geometry with PushPull.
This is an unfinished feature with some known issues and many unknown ones. It may also crash on you unexpectedly, so use at your own risk :slight_smile:
For serious work, always use the Appstore version of iRhino3D.
Enabling PushPull Mode
PushPull mode is disabled by default, you can enable it in Settings > Extra > PushPull. Once enabled, you should see a new row of button on the bottom of the screen.
Known Limitations
  • Selection and snapping: known bug with object selection and snapping.
    • Workaround: double tap to “Zoom to Extents”
