I’ve never seen this before: How can the for-loop index variable “t” exceed itself inside its own for-loop in the code below?
I know this from catching an error (the code below armed with a try-catch block) which tells me that “t” has a value of 5 (causing crash) despite the end of the range is, say 3 (star_indices.Length = 3).
So, how is it possible that “t” is greater than the upper bounds of the array?
try
for (var j = 0; j < tvi_connected.Length; j++)
var star_indices = tvertices.ConnectedTopologyVertices(tvi_connected[j]);
mv_points[j + 1] = new GH_Point[star_indices.Length];
for (var t = 0; t < star_indices.Length; t++) // <--- FROM HERE
var star_t = star_indices[t];
if (visited_indices.Contains(star_t))
continue;
visited_indices.Add(star_t);
mv_points[j + 1][t] = new GH_Point(tvertices[star_t]);
catch ... kaboom! ( t > .length! )
< scratching head >
What is going on here? What do you see here which I don’t see? I mean, only the code from “for(var t=0, ...)” is relevant…
True code, but the cause wasn’t t although the value of “t” was scrambled in the crash report. So you were right Nathan!
It turns out that the cause of the error was instead a too small mv_points array. Adding + 1 to the length on Create, fixed the problem.
Sorry for bothering you guys. I blame the crash report which put me on the wrong track (about “t”) … which is actually true, but embarrassing nevertheless.
And if you’re prototyping and don’t know the array length in advance…
If the array won’t occupy too much memory one can of course make a full (V or TV) length array check, but if need for resetting the values while working only in narrower ranges at the time, then resetting a full length array also takes time, so sometimes a Contains check is the easy way out.
But yes, I use array checks like this all the time for a reason.
