in an attempt to create a simple HoneyBee model for environmental analysis, and having exported Rooms
, Windows
from Revit to GH/Rhino using Speckle, I obtain the following:
- a group of objects/breps representing a building’s windows (say called “obj_list”) - in blue
- a group of vertical surfaces (say called “srf_list”) that represent the simplified walls for the environmental model - these are faces of closed breps that the
honeybee
plugin correctly recognises as thermal zones - in yellow.
I have asked ChatGPT (actually GrasshopperGPT
) to create a python script to project each of these objects as flat surfaces onto the “srf_list”, perhaps fitting planes on those “srf_list” and looking for the closest planes to each of the center points from “obj_list”.
GrasshopperGPT stated it created a script that:
- Converts GUIDs to Rhino Geometry objects.
- Calculates the center point of each object’s bounding box.
- Extracts planes from the vertical surfaces.
- Finds the closest plane to each center point.
- Projects the objects onto these planes.
However, the script created randomly placed and oriented objects, as per following image:
I am attaching the script GPT created, which I implemented using a GHPython
component.
import Rhino.Geometry as rg
import scriptcontext as sc
def convert_guid_to_geometry(guid):
""" Convert a Guid to a Rhino Geometry object. """
rhino_object = sc.doc.Objects.Find(guid)
return rhino_object.Geometry if rhino_object else None
def get_center_point(brep):
""" Get the center point of a brep's bounding box. """
bbox = brep.GetBoundingBox(True)
return bbox.Center
def get_planes_from_surfaces(surfaces):
""" Extract planes from a list of surfaces. """
planes = []
for surface in surfaces:
if isinstance(surface, rg.Surface) or isinstance(surface, rg.Brep):
surface_to_use = surface if isinstance(surface, rg.Surface) else surface.Faces[0]
plane = surface_to_use.TryGetPlane()[1]
if plane:
planes.append(plane)
return planes
def find_closest_plane(point, planes):
""" Find the closest plane to a given point. """
min_distance = float('inf')
closest_plane = None
for plane in planes:
distance = rg.Point3d.DistanceTo(plane.ClosestPoint(point), point)
if distance < min_distance:
min_distance = distance
closest_plane = plane
return closest_plane
def project_to_closest_plane(objects, planes):
projected_objects = []
for obj in objects:
center_point = get_center_point(obj)
closest_plane = find_closest_plane(center_point, planes)
if closest_plane:
# Project the object onto the plane
transform = rg.Transform.PlaneToPlane(rg.Plane.WorldXY, closest_plane)
projected_obj = obj.Duplicate()
projected_obj.Transform(transform)
projected_objects.append(projected_obj)
return projected_objects
# Assuming 'obj_list' and 'srf_list' are your input lists of Guids
obj_list = [convert_guid_to_geometry(obj) for obj in obj_list]
srf_list = [convert_guid_to_geometry(srf) for srf in srf_list]
planes = get_planes_from_surfaces(srf_list)
projected = project_to_closest_plane(obj_list, planes)
