Hello Dear Forum
as you can see rhino tweens the surface wrong because of the diagonal placement of the sphere
is there a trick?
thanks
Hello Dear Forum
is there a trick?
thanks
what command line settings are you using?
hey iam using tween surfaces
Hello - I am not getting deformed spheres so far here - can you post the inputs?
Hi @d.pfifferling - The issue doesn’t seem related to the diagonal. It has to do with the UV direction of the starting sphere being different to the UV dir of the end sphere. See below:
Does that help?
ah ok I see
do you know if there is a trick to kinda reset it to normal ?
i see you posted a video but its super tiny
thanks a lot
regards david
@Vanessa - here too, your video clip shows up < postage stamp size… weird, do you see it as normal at your end?
I converted to MP4. Something is up with posting GIFs.
thanks a lot Vanessa
