Problem with lofting
Hello, first time posting a question - I hope I include enough information :stuck_out_tongue:
I am trying to loft the joined inner and outer curves after shelling a brep with ‘ShellPsrf’. In this way I hope to get the miter surfaces then cap each piece, leaving the bottom open and flat. See below:
It works but one section is twisting. I’m trying to create a robust bit of code that will give me those miters regardless what shape I set into the starting Brep param.
Below is what I am aiming for after baking:
Please help and thank you :slight_smile:
Miter tool.gh (14.9 KB)
Hello,I don’t know why, but I couldn’t get the package manager to connect now, so I wrote it in C#.
How about this?
Shell.gh (12.4 KB)
Miter Tool.gh (14.5 KB)
Thanks to you both so far :slight_smile:
Mahdiyar, that worked well for the 5 sided pyramid, but when I tried it on a more irregular shape eg the one shown below…
… I get fragmented results:
I’ve attached your attempt below with this new shape. I know that anything is possible with Grasshopper, but am I asking too much for one bit of code to miter all shapes without unique tweaks each time?
Miter tool (post-Mahdiyar’s input).gh (15.8 KB)
Try this:
Miter tool_v2.gh (18.8 KB)
That’s the one Adam, amazing to finally have the answer :slight_smile: now I just need to try understand what you’ve done… haha
