Hello everybody,
I’m trying to implement multithreading (parallel computing), for a demanding for loop-portion of a Python script, I’m currently working on.
I’ve read @stevebaer’s post on the subject from a while back and tried to accomplish a similar thing with System.Threading.Tasks.Parallel.ForEach()
I get the following error:
Runtime error (ArgumentTypeException): The type arguments for method ‘ForEach’ cannot be inferred from the usage. Try specifying the type arguments explicitly.
Traceback:
line 28, in update
I understand that Parallel.ForEach
takes 2 parameters: a list of objects of type x, and a method that takes in one object of the same type x and returns nothing.
Here may reside one problem, since in Python (at least I think so), you don’t declare the type of the items in your list, and the type of the list itself would be, well, ‘list’ and not type x.
Here’s how I call Parallel.ForEach
import System.Threading.Tasks as tasks
tasks.Parallel.ForEach(self.agents, self._compute_agent_velocity)
I pass it a list of class instances self.agents
, of the same class Agent
, as an iterable, and the method self._compute_agent_velocity()
. The method takes in one agent instance and returns nothing. The list of agent instances, as well the method, are both parts of the class ParticleSystem
import Rhino.Geometry as rg
import random
class ParticleSystem:
def __init__(self, agent_count=100, use_parallel=True):
self.agent_count = agent_count
self.use_parallel = use_parallel
self.agents = [] # gets passed to Parallel.ForEach()
for i in range(self.agent_count):
agent = Agent(
self._get_random_point(0.0, 30.0, 0.0, 30.0, 0.0, 30.0),
self._get_random_unit_vector() * 4.0)
agent.flock_system = self
self.agents.append(agent)
def update(self):
"""Method that calls Parallel.ForEach()."""
# Regular for loop
if not self.use_parallel:
for agent in self.agents:
neighbours = self._find_neighbours(agent)
agent._compute_desired_velocity(neighbours)
# Multithreaded for loop
else:
tasks.Parallel.ForEach(self.agents, self._compute_agent_desired_velocity)
agent.update_veloctiy_and_position()
def _compute_agent_desired_velocity(self, agent):
"""Method that gets passed to Parallel.ForEach()."""
def _find_neighbours(self, agent):
neighbours = []
for neighbour in self.agents:
dist = neighbour.position.DistanceTo(agent.position)
if neighbour != agent and dist < 1.500:
neighbours.append(neighbour)
return neighbours
def _get_random_point(self, min_x, max_x, min_y, max_y, min_z, max_z):
x = min_x + (max_x - min_x) * random.random()
y = min_y + (max_y - min_y) * random.random()
z = min_z + (max_z - min_z) * random.random()
return rg.Point3d(x, y, z)
def _get_random_unit_vector(self, three=True):
phi = 2.0 * math.pi * random.random()
theta = math.acos(2.0 * random.random() - 1.0)
x = math.sin(theta) * math.cos(phi)
y = math.sin(theta) * math.sin(phi)
z = math.cos(theta)
return rg.Vector3d(x, y, z)
class Agent:
def __init__(self, position, velocity):
self.position = position
self.velocity = velocity
self.desired_velocity = rg.Vector3d.Zero
self.particle_system = None
def update_veloctiy_and_position(self):
self.velocity = 0.97 * self.velocity + 0.03 * self.desired_velocity
if self.velocity.Length > 8.0:
self.velocity *= 8.0 / self.velocity.Length
elif self.velocity.Length < 4.0:
self.velocity *= 4.0 / self.velocity.Length
self.position += self.velocity * self.particle_system.time_step
def _compute_desired_velocity(self, neighbours):
bounding_box_size = 30.0
# Control boundary
if self.position.X < 0.0:
self.desired_velocity += rg.Vector3d(-self.position.X, 0.0, 0.0)
elif self.position.X > bounding_box_size:
self.desired_velocity += rg.Vector3d(bounding_box_size - self.position.X, 0.0, 0.0)
if self.position.Y < 0.0:
self.desired_velocity += rg.Vector3d(0.0, -self.position.Y, 0.0)
elif self.position.Y > bounding_box_size:
self.desired_velocity += rg.Vector3d(0.0, bounding_box_size - self.position.Y, 0.0)
if self.position.Z < 0.0:
self.desired_velocity += rg.Vector3d(0.0, 0.0, -self.position.Z)
elif self.position.Z > bounding_box_size:
self.desired_velocity += rg.Vector3d(0.0, 0.0, bounding_box_size - self.position.Z)
Please note that I’ve abstracted the code a bit, to make it shorter and protect some parts.
Any help is greatly appreciated!
