I am working to create a VB.net component that can take a text list of parameters and read values from that file. I want to then use those values to run the rest of my definition.
I can’t seem to get the function to work for some reason. I’ve gone over it with as minutely as I can and completely rewrote it thinking perhaps that a different structure would somehow eliminate the problem.
Is there something I’m overlooking or is there just a completely better way to do this(I have no doubt there is!)
Much thanks for any input…
Here is my code from the VB.net component and the necessary files
Private Sub RunScript(ByVal x As List(Of Object), ByRef A As Object, ByRef B As Object)
A = GetValue(21, x)
End Sub
'<Custom additional code>
Function GetValue(lineNumber As String, paramList As List(Of Object)) As String
Dim parameter As String = ""
For Each i As String In paramList
Dim line As String
Dim number As String
Dim commaLocation As Integer
Dim equalsLocation As Integer
' put the line into a variable
line = paramList(i)
' get the location of the comma and equals sign
commaLocation = line.IndexOf(",")
equalsLocation = line.IndexOf("=")
' put the line number into a variable
number = line.Substring(0, commaLocation - 1)
If lineNumber = number Then
' put the parameter into a variable
parameter = line.Substring(equalsLocation + 1)
End If
Next
Return parameter
End Function
'</Custom additional code>
End Class
NOTE: this code is different from the code in the file, it has several fixes.
Function ParseValues(
data As List(Of String),
indices As List(Of Int32),
names As List(Of String),
values As List(Of String)) As Integer
Dim counter As Int32 = 0
For Each datum As String In data
If (String.IsNullOrEmpty(datum)) Then
Continue For
End If
Dim commaIndex As Int32 = datum.IndexOf(","c)
Dim equalsIndex As Int32 = datum.IndexOf("="c)
If (commaIndex < 0) Then Continue For
Dim index As Int32
Dim name As String
Dim value As String
If (Not Int32.TryParse(datum.Substring(0, commaIndex), index)) Then
Continue For
End If
If (equalsIndex < 0) Then
name = datum.Substring(commaIndex + 1)
value = String.Empty
Else
name = datum.Substring(commaIndex + 1, equalsIndex - commaIndex - 1)
value = datum.Substring(equalsIndex + 1)
End If
indices.Add(index)
names.Add(name)
values.Add(value)
counter += 1
Next
Return counter
End Function
Ideally though you’d encapsulate the parsing and formatting into a custom made class. You’d create a new type which knows how to (de)serialize itself from and to the text lines, then it’ll be much easier to write code that directly deals with your files.
Function ParseData(lines As List(Of String)) As List(Of Datum)
Dim entries As New List(Of Datum)
For Each line As String In lines
Dim entry As Datum = Datum.TryParse(line)
If (entry IsNot Nothing) Then
entries.Add(entry)
End If
Next
Return entries
End Function
''' <summary>
''' Represents a single datum entry.
''' </summary>
Public Class Datum
Private ReadOnly _index As Int32
Private ReadOnly _name As String
Private ReadOnly _value As String
''' <summary>
''' Create a new datum.
''' </summary>
''' <param name="index">Datum index.</param>
''' <param name="name">Datum name.</param>
''' <param name="value">Optional datum value.</param>
Public Sub New(index As Int32, name As String, value As String)
If (String.IsNullOrEmpty(name)) Then Throw New ArgumentNullException()
If (value Is Nothing) Then value = String.Empty
_index = index
_name = name
_value = value
End Sub
''' <summary>
''' Optionally this method could throw exceptions if the line isn't
''' formatted correctly, or it could choose to return an error message.
''' </summary>
''' <param name="line">Line to parsr.</param>
''' <returns>Datum instance or null.</returns>
Public Shared Function TryParse(line As String) As Datum
If (String.IsNullOrEmpty(line)) Then Return Nothing
Dim commaIndex As Int32 = line.IndexOf(","c)
Dim equalsIndex As Int32 = line.IndexOf("="c)
If (commaIndex < 0) Then Return Nothing
Dim index As Int32
Dim name As String
Dim value As String
If (Not Int32.TryParse(line.Substring(0, commaIndex), index)) Then
Return Nothing
End If
name = line.Substring(commaIndex + 1)
Else
name = line.Substring(commaIndex + 1, equalsIndex - commaIndex - 1)
value = line.Substring(equalsIndex + 1)
End If
Return New Datum(index, name, value)
End Function
Public ReadOnly Property Index As Int32
Get
Return _index
End Get
End Property
Public ReadOnly Property Name As String
Get
Return _name
End Get
End Property
Public ReadOnly Property Value As String
Get
Return _value
End Get
End Property
Public Overrides Function ToString() As String
If (String.IsNullOrEmpty(Value)) Then
Return String.Format("{0},{1}", Index, Name)
Else
Return String.Format("{0},{1}={2}", Index, Name, Value)
End If
End Function
End Class
