Hi everyone, I hope you are all doing ok.
Here’s my problem.
I’m an industrial design student, and I’m learning how to use Rhino 6.
We are making a model of a train, really simple parts four vagons. But at the moment I start making plans i use command make 2d, and my computer stars ventilating really loudly, and the entire process of making 2d takes a little bit longer than an hour, my other classmates didn’t have that problem.
I don’t think is my computer, since is a HP workstation studio g3
And I bought it specifically for this uses, since I dug up, that is really good for my purposes.
It’s an
i7-7th generation
12 gb of ram
A Nvidia Quadro m1000 4gb
512gb of ssd
If anyone of you had an answer that might help, I would really appreciated.
Thank you for your time
Be save.
Boah… if the program crash I don’t have so much solutions ¯\(ツ)/¯. Are you sure you don’t have bad geometries in your model (run ‘_SelBadObjects’ command)?
Otherwise I guess someone from McNeel should have a look to that issue…
Hello - if you have a file that shows the problem, please post it here or send to tech@mcneel.com, to my attention, with a link back here in your comments; I’ll take a look.
