I must collect coordinate points (x, y, z) and therefor used a list to store them as tuples. Although I use the round function to just get values with two decimals, the values in the list are extended to values with 14 decimals.
So I tried to find the problem and came up with:
matrix = []
x = 543.1
y = 345.33
z = 369.329
matrix.append([x, y, z])
x = 543.2
y = 345.35
z = 369.327
x = 543.3
y = 345.37
z = 369.326
x = 543.5
y = 345.38
z = 369.325
x = round(543.6738448321, 2)
y = round(1345.33324332, 3)
z = round(369.84264326, 4)
for m in matrix:
print(m)
listDecimals.py (648 Bytes)
I extended the output with different variations. still very odd, but the last one is interesting, as it shows the values of x as they were given in the source code.
Bye, MillingGuy
Thanks, Dale. Yep… floating and base10 or base2. All not that easy.
But I’m still wondering, why …
matrix = []
x = 543.1
y = 345.33
z = 369.329
print(matrix[0])
print(matrix[0][0], matrix[0][1], matrix[0][2])
for m in matrix:
print(m)
print(matrix[0][0])
matrix = []
x = 543.6738448321
y = 1345.33324332
z = 369.84264326
for m in matrix:
print(m)
print("---")
for m in matrix:
print(m[0], m[1], m[2])
print("---")
for m in matrix:
print "{},{},{}".format(m[0],m[1],m[2])
print("---")
for m in matrix:
print "{:.2f},{:.3f},{:.4f}".format(m[0],m[1],m[2])
Hi @Helvetosaur
hmm… is this for me or @dale ?
Your output is either strange, too. Why is z=369.8426 well done in second output, whereas x and y remains with more decimals as defined with the round function?
Yes… output will be done correct, if one is direct accessing the values given the system no chance to interpret it to be a list:
print("---")
for m in matrix:
print(m[0])
print(m[1])
print(m[2])
print(str(m[0]) + ", " + str(m[1]) + ", " + str(m[2]))
All floating point numbers are likely to have some ‘fuzz’. What you think is 543.67 may really be stored as 543.6700000002
When you print, python turns numbers into strings. How it does that exactly and what the rules are for truncation are is somewhat of a mystery to me - so I prefer to be certain of my output. The format method provides that certainty - as well as letting you do the truncation yourself if you want.
