Hello everyone,
I’m modelling a residential district and I wanted to populate it with trees. Apparently it’s not possible to manipulate blocks in Grasshopper so can a block be placed to all selected points in Rhino?
Thank you all
Best,
Jonas
Hello everyone,
Thank you all
Best,
Jonas
i am using this old script to place trees with optional random z-rotation. Just run the script, select the tree block to populate, pick the basepoint and then select all points…
CopyObjectsToPoints_RH4.rvb (2.2 KB)
c.
Thank you, Clement, will try! Finally the time has come to learn to use scripts. ![]()
-j.
