Polyline of specific length
Hi there :slight_smile:
I was doing some Egress calculations, and wondered if the following feature is possible or exists already.
With a polyline, is it possible to set a specific total length such that not mater how many clicks you make, it will stop after the specified length?
Best,
Jeremy
Hi Jeremy - it does not exist now - if all you need is a polyline from placed points and none of the fancy polyline tools it should be easy to script .
LimitedPolyline.py (6.6 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
Thanks Pascal, I will try the script :slight_smile:
This is truly excellent Pascal; thanks so much :slight_smile:
-Jeremy
@jdelavaulx fwiw, I entertained myself adding more feedback - updated above, no idea if that is helpful in real ife or not.
Already got the alias LPL :slight_smile:
