PointCount is not defined in python?
I am facing an error in using the PointCount in python
its giving an error of PointCount is not defined. Any suggestions?
import Rhino
import Rhino.Geometry as rg
from random import *
import System.Drawing
#step 1 moving vertices
def moveVertices(polyline):
    ptNum = PointCount
    pts = []
    planePts = []
    for i in range(ptNum):
        pts.append(polyline.Point(i))
        if len(pts) <= 3:
            planePts.append(pts[i])
    plane = rg.Plane(planePts[0], planePts[1], planePts[2])
        scalar = uniform(0.0, 2.0)
        vec = plane.ZAxis * scalar
        pts[i] = pts[i] + vec
    pts[-1] = pts[0]
    return pts, plane
a = moveVertices(cells[5])[0]
[pythontest.gh|attachment](upload://zW2NnEzGTCYgCswP7M2zeJAqEhc.gh) (12.2 KB)
pythontest.gh (12.2 KB)
I found this syntax in the rhino API for c# and vp but it doesn’t contain how to use it in python
What is this line intending to do?
to count the voronoi polygon point counts
I am trying to move the voronoi points up in the z axis
this script should move the points of one voronoi polygon up via
here is my updated script but still no luck, it is thowing the error of PointCount:
import Rhino
seed(1000)
    ptNum = PointCount
    pts = []
    planePts = []
        if len(pts) <= 3:
    pts[-1] = pts[0]
    return pts, plane
#Step 2: cell type A
def divPolygon(vertices, plane):
    midIdx = len(vertices) //2
    startPt = vertices[0]
    endPt = vertices [midIdx]
    centroid = getCentroid(vertices)
    return centroid
    xOff = plane.XAxis * uniform(0.0, 2.0)
    yOff = plane.YAxis * uniform(0.0, 2.0)
    zOff = plane.ZAxis * uniform(0.5, 2.0)
    centroid[0] += centroid[0] * xOff[0] + yOff[0] + zOff[0]
    centroid[1] += centroid[0] * yOff+ yOff[1] + zOff[1]
    centroid[2] = centroid[2] * zOff+ yOff[2] + zOff[2]
    curve = rg.Curve.CreateInterpolatedCurve([startPt, centroid, endPt], 3)
    curve = japCurve(curve, plane, 24)
    curve = rg.PolylneCurve(curve)
    halfA = rg.PolylineCurve(vertices[:midIdx+1])
    halfB = rg.PolylineCurve(vertices[vertices:1])
    halfB.Reverse()
    return curve, halfA, halfB
#Helper functions
def getCentroid(vertices):
    centroid = [0,0,0]
    for i in range(len(vertices)-1):
        centroid[0] += vertices[i][0]
        centroid[1] += vertices[i][1]
        centroid[2] += vertices[i][2]
    centroid = [val / (len(vertices) - 1) for val in centroid]
    return rg.Point3d(centroid[0], centroid[1], centroid[2])
#JagCurve
def JagCurve(curve, plane, divisions):
    totallen = curve.GetLength()
    lenStep = totallen / divisions
    ts = curve.DivideByLength(lenStep, True)
    ts = [t for t in ts]
    offDist = uniform(0.1, 0.3)
    pts = []
    for i in range(len(ts)):
    t = ts[i]
    newPt = curve.PointAt(t)
    if i % 2 != 0 and i != (len(ts) -1):
        vec = curve.CurvatureAt(t)
        vec.unitize()
        vec = -plane.ZAxis + vec
        vec = vec * offDist
        newPt = newPt + vec
        pts.append(newPt)
        return pts
testPolygon=moveVertices(cells[5])
a = divPolygon(testPolygon[0], testPolygon[1])
b = testPolygon[0]
I solved it thank you
