For the life of me I cannot work out why point group is not working for these two points. They are 0 distance apart - I would expect a single branch of two items to come out. Weirdly, when I add a point at 0,0,0 they do group together
Strange but it seems that if your input to the Point Groups component is a group of identical points it outputs a DataTree with 1 point in each branch. Outcome seems to be the same regardless of how many points. 2 identical points outputs 2 branches, 100 identical points outputs 100 branches. As you’ve described, adding 1 unique point to the list causes the component to produce the expected output.
230712_point_groups_bug.gh (9.4 KB)
Seems like a bug to me.
-Kevin
Has there been any update on this bug reported? I am seeing the same scenario, duplicate points are not recognized as within the proximity range and each instance gets a branch.
I found the attached C# script in a another thread, by @magicteddy that seems to be an improvement but does not provide the index list.
GroupPointsC#.gh (6.6 KB)
