Dale,
A sincere thanks. Here are some notes that I hope might help you and your team. I have no idea if this is something you can fix quickly but it’d be appreciated tremendously if so.
Naming the plugin.rui and plugin.rhp and altering the rhi installer structure to appear like this (below) appears to work such that when rhino first launches with a new plugin - as installed by the rhi - will actually show the plugin rui toolbar.Structure that achieves this is shown at the bottom of this entry – you might consider updating the installer description page [ here ] to reflect this information.
Button icon of loaded toolbar - Shows Blank ( * * Appears to be a bug * * ).
Toolbar buttons do not save icons unless both left and right mouse button actions are set to a command. -
Tab icon of loaded toolbar - Shows Correctly.
. This icon, like the button icon was supplied with three different image sizes per your standards and works.
Structure which works per point 1 is:
PluginName/
. Rhino 5.0/
…x64/
…PluginName.rhp
…PluginName.rui
…x86/
…PluginName.rhp
…PluginName.rui
