Dear All,
I wrote a small script in python to place points with incrementing values in a rhino drawing.
Problems occur when I try to loop the while statement and try to increment the variable.
I wrote some comments in the python script:
Place-Point-ID.py (944 Bytes)
Thank you for your time.
Kind Regards,
Jaap Bijlstra
Here is some sample code with comments - post back if there is anything you don’t understand:
def placepoint():
#loop pointcreate with name
#Use an integer for nValue, not a string if you are going to increment
nValue=rs.GetInteger("Starting Value")
if nValue is None: return
#define plane outside loop
#Plane_loop= rs.WorldXYPlane()
Plane_move= rs.WorldXYPlane()
while True:
#nValue=nLoop
point_create=rs.GetPoint("Add Point")
if point_create is not None: #this is a correct statement
#could also be simply if point_create:
pnt = rs.AddPoint(point_create)
#print pnt
#Plane_move= rs.MovePlane(Plane_loop,point_create)
#can also do this like the following:
Plane_move.Origin=point_create
#convert integer to string for text
rs.ObjectName(pnt,str(nValue))
rs.AddText(str(nValue),Plane_move,300)
#Increment one number,didn't succeed?
#as you originally defined it nValue is a string
#you can't increment a string!
#Use an integer instead and increment it in the loop
nValue+=1
else:
#is it necessary to make bLoop Global? - No.
#just break out of the loop with break
break
# call the function defined above
placepoint()
Thank you for the remarks about the python code. It is better to wrap more code in the definition I guess. I just added a string prefix to the .ObjectName and .Addtext and I got no errors in the string concatenation.
The ‘nValue+=1’ looks weird for me but that is how Python reads the code I think.
Regards,
Jaap
def placepoint():
String_prefix=rs.GetString("Please enter Prefix")
while True:
rs.ObjectName(pnt,String_prefix+str(nValue))
rs.AddText(String_prefix+str(nValue),Plane_move,300)
nValue+=1 # Increment one number
else:
break
if __name__ == "__main__":
placepoint()
Yes, n+=1 looks strange, it’s python shorthand for n=n+1 You can also do -=, *= etc.
ahh okay. Thank you for your explanation!
