after entering a digital photo using the picture command, only a small part of the image is visible.
Previous executions of the command ran without problems (about 3 times), but after that the above-mentioned problem appeared. As I use photos for mapping backgrounds, it would be beneficial if there was a solution to the problem.
I have already reduced the size and resolution of the digital photos and converted the working color space to RGB sRGB IE61966-2.1 (before origin embedded display P3, canon CR2 file) according to Photoshop.
Sometimes the color profile was embedded in the output png file, sometimes not. Nevertheless, the same error always appeared, even with different digital photos.
On the first few looks I could not find a suitable topic in the forum.
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 16Gb)
Mac Model Identifier: iMac20,1
Language: de-DE (MacOS default)
AMD Radeon Pro 5500 XT OpenGL Engine (OpenGL ver:4.1 ATI-4.9.51)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8176 MB
Graphics: AMD Radeon Pro 5500 XT
Displays: iMac (217dpi 2x), SyncMaster (305dpi 1x)
Graphics processors
AMD Radeon Pro 5500 XT (8 GB)
iMac (2560 x 1440)
For the last photo (it was in portrait orientation), it helped to rotate it 90 degrees in advance, save it in Preview (OS), and then load it into Rhino. After that it was displayed correctly, but in Rhino needed to be rotate back 90 degrees.
done… no change… but if I rotate the images 90 degrees in preview (OS), save them, then rotate them back 90 degrees in preview and save them again, they load correctly in Rhino…
