PickObjects with PickContext return empty
I want to implement a plugin similar built in BlockEdit and edit block when double click imitating SU, but PickObjects with PickContext return empty. The sample code is below
    class BlockEditor:MouseCallback
        protected override void OnMouseDoubleClick(MouseCallbackEventArgs e)
            RhinoObject rhinoObject = GetPickedObject(e);
            if(null == rhinoObject)
                return;
        protected RhinoObject GetPickedObject(MouseCallbackEventArgs e)
            var pickContext = new PickContext
                View = e.View,
                PickStyle = PickStyle.PointPick,
            Guid displayModeId = e.View.ActiveViewport.DisplayMode.Id;
            if(displayModeId == DisplayModeDescription.ShadedId ||
               displayModeId == DisplayModeDescription.RenderedId)
                pickContext.PickMode = PickMode.Shaded;
            var xform = e.View.ActiveViewport.GetPickTransform(e.ViewportPoint);
            pickContext.SetPickTransform(xform);
            Line pick_line;
            e.View.ActiveViewport.GetFrustumLine(e.ViewportPoint.X, e.ViewportPoint.Y, out pick_line);
            pickContext.PickLine = pick_line;
            pickContext.UpdateClippingPlanes();
            ObjRef[] objRefs = Doc.Objects.PickObjects(pickContext);
            if (null == objRefs || !objRefs.Any())
                return null;
            return objRefs[0].Object();
I have used similar code to pick objects with GetPoint, it works. The code is below
    public class GetObject:GetPoint
        protected override void OnMouseMove(GetPointMouseEventArgs e)
            var pick_context = new PickContext
                View = e.Viewport.ParentView,
            var xform = e.Viewport.GetPickTransform(e.WindowPoint);
            pick_context.SetPickTransform(xform);
            Line pick_line;
            e.Viewport.GetFrustumLine(e.WindowPoint.X, e.WindowPoint.Y, out pick_line);
            pick_context.PickLine = pick_line;
            pick_context.UpdateClippingPlanes();
            ObjRef[] objRefs = RhinoDoc.ActiveDoc.Objects.PickObjects(pick_context);
                return;
Rhino version:Version 7 SR13(7.13.21348.13001, 2021-12-14)
OS: Windows 10
Nuget package: 7.13.21348.13000
Hi @RyanZhou,
Why not just use GetObject?
– Dale
The goal is to select and edit a block when double click, it is ok if GetObject can achieve.
Double click to edit block is used by SU, which is more quick than Rhino’s special for nested block.
