Hi guys, I am new to grasshopper and was trying to pick colours from the slope heights individually, but haven’t had any luck in making it work, since it picks all the colours together in every time. Is there a way to make it pick the colours individually?.
I wanted the colours to be separated according to the slope heights, if it was possible. So if the range of the colours is 6-10 in the case of the script before, It takes out green colour from it. Is it possible to project the value of the slope z points to the colours and put a range to take out the colours from it?
The plugin is called ‘Bison’ which in this case is making a slope map from the mesh. The Z values are heights yes, but I wanted to know if there was some way to make the colours out according to those Z values, so if there is a Z value in a certain range, it only takes out the colour green from the mesh.
Sorry, I have just started with grasshopper and thank you for responding.
I know where to find plugins, I just don’t want to install it. There are ways to do without it but maybe it would be better if someone else helps you who has the plugin or is willing to install it.
I want to just separate the colors using dispatch or some other component and get the cells in one color separately. The issue I was facing was that I couldn’t get single colors cells separate.
I’ve made a few small changes. Whatever it is you want to do, I’m sure you can do it without a plugin if you understand this code.
Used QRMesh(Quad Remesh) instead of Mesh UV. Produces mesh faces aligned with the original surface instead of aligned diagonally (with the untrimmed surface UV curves).
Replaced the fixed value ‘16’ with a ‘NumColors’ slider(blue group) to adjust color “resolution”.
Added a ‘All or One’Value List(yellow group) to switch between showing all colors or just the one selected with the ‘Index’ slider in the purple group.
I just updated this code in another thread (explained there) to avoid using EdgeSrf:
Trial 2_2023Sep21a.gh (67.5 KB) (UPDATED below)
P.S. I found a component to get face centroids directly instead of using the average of face boundary discontinuity points. The result appears to be identical though, so I don’t know why a few faces have different colors (Z values) from the Sep17a version using EdgeSrf.
P.P.S. Not that it matters in this case but I added a fix internal to the CMesh cluster to correctly handle multiple meshes in a data tree. I’ll replace two earlier versions in this post with this one: Trial 2_2023Sep24a.gh (70.4 KB)
