Phantom Block that won't delete even in block manager
I seem to have a phantom block file and can’t find it. I know it exists because of a layer that upon trying to delete returns the error “There is a block definition named “J2.0>Panel_I2.0 Template.3dm:J2.0” on layer “Layer 01”. Use BlockManager command to delete this block before trying to delete this layer.”
Here are things I have tried to delete said block:
  1. Using blockManger, delete the block. Even though the block is listed, the option to delete was greyed out and inaccessible.
  2. Select instances of the block. No instances exist.
  3. Perform the count command in block manager to confirm no instances exists. Count is also greyed out.
  4. Purge, to no effect.
  5. Check all blocks to see if it was nested. None of my blocks contain this phantom block. Used purge just in case to no effect.
  6. delete all block instances and use purge. The phantom block still exists and so does the associated layer. The file is empty but still contains these.
  7. Turned on all layers, used show, unlock, and purge to no effect. Still no instances of the phantom block nor can I delete the block or layer.
I am at a loss of what to do to delete this block and the dumby layer. Is there some kind of debug command I can use that will help me find this block, where it is, or allow me to force delete it?
Can you post the 3dm file?
This is a very large file (2gig about). How should I go about posting it?
Hi Cameron - can you post the otherwise stripped file to begin with? If the contents are confidential, please send to tech@mcneel.com, with a link back here in your comments.
Personally, I don’t use blocks, but when I do I end up running the following routine:
1.) ExplodeBlock/AllBlocks/GroupOutput=Yes
2.) Purge/BlockDefinitions=Yes
This is pretty much my solution to Block issues everytime. Of course the blocks have to be visible/unlocked and not on locked layers or hidden layers etc.
230814 Coordination Model Purged.3dm (499.6 KB)
Here is my model, reduced down to just the phantom block. Good luck
I would love to not use blocks, but it is the only way to reference external geometry that is repeated multiple times around the project. If you know another solution, I’m all ears.
I’ve honestly yet to utilize such power. I wish I was more familiar with it. I’ve just never bothered trying much doing projects that way in Rhino.
I’ll check out the phantom block, brb.
so far I’m not sure what this is:
Update: I just restarted my computer due and went to open my Rhino file. Being a glutton for punishment, I tried to delete the layer with the phantom block and lo and behold, it just deleted.
So I have no idea where this came from, what was happening, etc but I will add “restart your computer” to the list of tricks to delete a phantom block.
Yeah, no issues here with the file you posted.
Interestingly I had this same issue a few months back, corgi also claimed to be missing (I hadn’t installed corgi that I was aware of) and I gave up and a restart fixed it for me as well. I never looked back :joy:
