the surface created with CreatePatch why is plane?
Hi gxyanjiaju - are you using the Patch command in Rhino or creating the patch surface in code? If the latter, you should check in on the Scripting or Developers forums.
If it is Rhino’s Patch command, please post a file with the input objects and an image of the settings you used.
Maybe I didn’t describe the problem clearly, I mean, why can we build a surface in patch in Rhino, but a plane with API CreatePatch?
I think this is a question for the developer forum. I’ll move it there for now.
Can you please post some sample source code, along with any relevant geometry, that is not working for you?
Thanks,
– Dale
