Hi All,
I have a list of 9 points to divide 3 points into 3 lists
in Gh i used Partition List, while in Py i used this code:
a = []
for i in range(3):
print "ID", i
b = []
a.append(b)
for j in range(3):
b.append(x[(3*i+j)])
print a
import ghpythonlib.treehelpers as gh
a = gh.list_to_tree(a)
the question is this:
it would be possible to have the same result in Py, using only rhinoscriptsyntax without using ghpythonlib?
Not really. rhinoscriptsyntax is meant for scripting in Rhino. In Grasshopper, you should use Node in Code or even better the API (RhinoCommon), which rhinoscriptsyntax is a wrapper of with some sugar on top. ghpyhtonlib on the other hand is also a wrapper for API functionality, but for GHPython explicitly.
