This is supposed to be basic, but I can’t seem to use parallel snap. Am I doing something wrong?
Can you please provide an example so we can see what you’re doing?
Thanks for the lightning fast answer! I was just shooting a video:
EDIT: using latest version 5.5.5 on latest macOS Catalina. I also use Rhino 6 for Windows and (not sure but) I think it’s ok there.
Hi - this seems to work fine on 5.5.5. Two things:
- Settings: Make sure that the
Parallels
option is turned on in thePreferences
- Workflow:
- Start the
Line
command - Place the start point of the line
- Create a
SmartTrack
point on the corner of the rectangle like you did in the video -
The next
SmartTrack
point needs to be on the start point of your line - not on the other corner of the rectangle
- Start the
Thank you. Turns out I hadn’t turned parallels on in the preferences.
