First off, thank you Arthur for making the Pachyderm plugin!
Secondly, I am new to acoustic simulations and I have a rather lengthy question regarding some settings / overall best practices.
What is the typical best practice for choosing acoustic properties settings when modeling a suspended ceiling absorber/island? From what I see, most manufacturers will provide the absorption / Sabine coefficients, but not much else. Realistically, if there is enough of a gap between the absorber and the ceiling (lets say > 2ft), some sound waves will be reflected, others absorbed, and some will also be transmitted through the surface (with some attenuation).
It seems possible choices are:
Option 1) Ignore any sound transmitting through it, and just use the absorption coefficients. Depending on the room setup, this may or may not be a reasonable approximation.
Option 2) Use the absorption setting and a semi-transparency setting. At first I was thinking this transmission setting was meaning the Power Transmission coefficient, but I realize it says, ā% non-absorbed transmitted energyā, so I think it is something else. I am now thinking this combination would have some rays pass through completely unobstructed, and some rays reflect or absorb, which is not really what Iām after, but perhaps can be an approximation?
Option 3) Use the absorption setting and transmission loss setting. This may be redundant though, so alternatively would I set the absorption to 0, and only adjust the transmission loss value? Any guidance on setting reasonable transmission loss values to correspond to something like a mineral wool ceiling absorber if all I have is a ātypicalā datasheet from a manufacturer with absorption values and maybe an overall density?
In general, how is the math/probability behaving when all of those settings are used together? e.g. if absorption coefficient is 0.6, and transparency coefficient is 0.7, for a single ray, what is the probability of reflection vs. absorption vs. transmission (and would that transmitted ray have the same energy or be reduced because of the absorption value)? Or if using transmission loss, does the absorption coefficient still get used, or is that ignored?
Any answers or guidance is appreciated. Thank you!
