Overlapping curve not flagged as selfintersecting. Isn't it?
Hi @pascal shouldn’t self overlapping curves flag as selfintersecting?
If I dra a polyline that goes “back and forth” over it self then it isn’t recognized as a selfintersecting curve.
The overlap is illustrated with the exaggerated red line:
Just make one and test it with this script:
import Rhino
polyline_id = rs.GetObject()
newPoly = rs.coercegeometry(polyline_id)
interEvent = Rhino.Geometry.Intersect.Intersection.CurveSelf(newPoly.ToNurbsCurve(), 0.001);
if interEvent:
    print "Number of intersections: "+str(len(interEvent))
    dots=[]
    rs.EnableRedraw(False)
    for i in range(len(interEvent)):
        point = interEvent[i].PointA
        dots.append(rs.AddTextDot(str(i+1),point) )
    rs.EnableRedraw(True)
    rs.GetString("Press Enter when Done")
    rs.DeleteObjects(dots)
else:
    print "no intersections"
Hei Jørgen -
I would consider it a bug if that red curve was flagged as a self-intersection.
If I put one of those inside endpoints on the same line, it does become a self-intersecting curve and is flagged correctly as such.
If that is not what you are seeing, we’ll need that curve as a 3dm file.
Hi Wim, the red curve is just to indicate how the black curve goes.
Try making a polyline with X = [0,10,5,15]
(from 0,0 to 10,0 to 5,0 to 15,0 in other words back and forth in the middle).
On my hand that curve returns no intersections.
Here is a testfile and I updated the code above slightly, so it states how many intersection events it encountered.
selfintersecting.3dm (128.9 KB)
Yep, I tested this too (in V7) with an overlapping polyline and it does not get selected by SelSelfIntersectingCrv nor does IntersectSelf find any intersections.
Thanks, Jørgen -
I see that when all 4 points are on the same line - RH-66652.
I reported that as an issue with SelSelfIntersectingCrv and possibly IntersectSelf but I see that Dale uses the CurveSelf method to test in RH-43624…
Takker,
