Good day
May I inquire more on how Orca derive its waterplane draft? This is because we have a set hull and fixed load conditions on weight, LCG and TCG.
Vessel has a forward trim but the Twp values did not reflect this; and was constant. Also where do these values come from?
Will appreciate useful information and be delighted to answer queries about this question
sd1
(Sd)
2
Hi Dominnic,
You can define the longitudinal positions of forward and aft perpendiculars either by:
- pulldown menu >Orca3D>Adv Stability>Subdivision>Design/Components>Edit Frames
- command “_OrcaFrameSystem”
- via the Orca3D side panel:
I hope this helps
Thank you
bhays
(Bhays)
3
Also, see the 2:19 mark of this video on the Orca3D Frame System: https://youtu.be/Cgq2NI_qwwA
